uc500-upgrade issue
Aug 6th, 2008
Im doing a new post because I rate the latest post before test the solution you give me.
Also Thanks to all people is contributing with comments, but I believe that with the UC500 is a little different, UC500 only support one language at time.
Thanks.
I just upgrade my uc500 with the US 3.2.1 version, now Im trying to upgrade to the es-CO version, I have problems.
I issue the following three commands:
software install upgrade url ftp://192.168.10.11/cue-vm-langpack.ise.3.2.1.pkg
software install clean url ftp://192.168.10.11/cue-vm-langpack.ise.3.2.1.pkg
software install add url ftp://192.168.10.11/cue-vm-langpack.ise.3.2.1.pkg
I receive the following error after each command:
AFTER TRY CLEAN
Error: The package contains only add-ons, which is not valid for clean-install
AFTER TRY ADD
Language add-ons found on the system (1):
Installed SKU Name (version)
* ENU CUE Voicemail US English (3.2.1.0)
Maximum allowed language add-ons (=1) already installed.
You can use "software uninstall" to remove add-ons.
AFTER TRY UPGRADE
The system will be brought to offline state for a brief period
and will be brought back to online state automatically
Calculating delta.... complete.
Running Script Processor for ui_upgrade
ui_upgrade scripts executed successfully.
Retrieving calculated file change sets:
- Installed file sets...complete.
- Target file change sets...complete.
Comparing changed source and target files...complete.
Calculating upgrade work order ... complete.
Creating uninstall change sets:
complete. No added files found.
- logging added components ... complete. No removed files found.
Clearing previous downgrade files ... complete.
Uninstall change set processing complete.
No work order generated for upgrade.
The system is back in online state
Rafael Jimenez Mon, 08/18/2008 - 08:31
Finally the upgrade works but doing the reinstallation from the monitor and boot helper.
installing the language you want.
