PIX 501 doing PPPoE. Can I VPN into it too?
Aug 6th, 2008
I have a PIX 501 that I want to set up to connect to my ISP via PPPoE. This, of course, would be on the outside interface. Is it possible to enable PPPoE on the outside interface AND be able to VPN into the same interface? If so can you show me a config example?
I'm not sure where I saw it (it's been about a year ago) but something makes me think that I can't do both on the same interface.
Please, any help is appreciated.
Marwan ALshawi Wed, 08/06/2008 - 07:12
sure u can
only u need static public ip address from ur isp
and it gonna be like any normal vpn
and apply the crypto map on the physical and dialer interfaces
this link how to configure pix pppoe
the folowing link how to use vpn with pppoe on router but the idea the same
and the following link contain alot of vpn examples
good luck
please, if hlepful rate
