How to install install CA-signed certificate in CiscoWorks LMS?
Aug 6th, 2008
Hello!
We have a root CA and wish to use CA-signed certificates in Cisco Works LMS. I cannot find in Cisco documentation how I can do that. Exactly:
1. How CW can issue enrollment request?
2. How CW can import CA-signed certificate?
Can anybody help me?
Thanks in advance!
Joe Clarke Wed, 08/06/2008 - 08:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
1. A CSR already exists under NMSROOT/MDC/Apache/conf/ssl. It's called server.csr. Assuming you specified all the correct parameters when you generated your self-signed cert, this one should be good to go. If not, you can adjust the parameters under Common Services > Server > Security > Certificate Setup.
2. The steps can be found by going to the location above, and clicking on the Help link. Or, more exactly, http://SERVER/help/cmf/sysadmin_self_sign_cert.html#wp466236
