1841 + 3g hwic issue -> can't ping from lan, LB not ok
Aug 6th, 2008
Hello i've a setup with a 1841 ((C1841-ADVIPSERVICESK9-M), Version 12.4(15)T3,
RELEASE SOFTWARE (fc1. With a 3g hwic.
The WAN connections work fine as long one of them (dsl/3g) is shutdown or disconnected. When both enabled there is no correct failover and I can't connect from LAN with telnet/http on the 1841 even as ping
