Error Message from DB Walker
Aug 6th, 2008
  • Gold, 750 points or more
Hello all,
when running DB Walker on a Unity 4.1(1) server on Windows 2003 I get the following output:
1699:(error) The 'SchemaMajorVersion' value is NULL in the row with 'Alias' value matching the primary server name in the 'Servers' table. This can cause problems if you try to upgrade this system to a newer version of Unity. Please contact TAC.
1700:(error) The 'SchemaMinorVersion' value is NULL in the row with 'Alias' value matching the primary server name in the 'Servers' table. This can cause problems if you try to upgrade this system to a newer version of Unity. Please contact TAC.
Anyone have a clue what could be causing this and what a resolution might be? Customer is wanting to upgrade to Unity 5.0(1) tonight and this is a concern.
Thanks in advance! All replies rated!
Overall Rating: 5 (3 ratings)
thfergus Wed, 08/06/2008 - 07:48
  • Cisco Employee,
Do you also see this error:
1694:(error) The [email protected]' property could not be found in the
'UnitySetupParameters' table. This can cause problems if you try to upgrade this system
travis-dennis_2 Wed, 08/06/2008 - 07:57
Hello Thomas,
We are not seeing that particular error message.
Travis
Tray Stoutmeyer Wed, 08/06/2008 - 08:10
  • Cisco Employee,
Try this Travis..
Start > Programs > Microsoft SQL Server > Enterprise Manager >select the untiy
primary server-->UntiyDB-->Tables-->Server and open table return all rows.
Basically the SchemaMajorVersion and SchemaMinorVersion needed changing from null to 3 and
20 respectively.
Tray
