ACE Capture full size Packtes
Aug 6th, 2008
i was seeking the switch to capture full size packets on the ACE Mdule with the the capture command.
The Docs say only that the capture must be configured to jumbo-frames but i have not found how to do this.
Overall Rating: 4.5 (2 ratings)
ivillegas Tue, 08/12/2008 - 05:49
To enable the packet capture function on the ACE for packet sniffing and network fault isolation, use the capture command in Exec mode. As part of the packet capture process, you specify whether to capture packets from all input interfaces or an individual VLAN interface.
Sbutzek Tue, 08/12/2008 - 05:56
i know how i enable the capture of packets, but i have no idea how i can capture the full packetsize (1500 Byte). I get only the headers (64 Byte).
Gilles Dufour Wed, 08/13/2008 - 00:06
The packet size is limited. There is no way to change it.
I personally recommend to use the MSFC 'monitor' command and span the tengig interface associated with the ACE module instead of using the ACE capture feature.
ropethic Thu, 08/14/2008 - 11:12
You are correct, admin guides states 1860 byte captures. Let research and I will post later today.
ropethic Thu, 08/14/2008 - 12:18
CSCsd32437 was fixed in 2.1.0, so you should be able to see full packets in ACE module and ACE appliance. if you are running 2.1.0+ or 3.1.0 on the appliance.
hope this helps
Gilles Dufour Mon, 08/18/2008 - 00:25
This is actually not a fix but a feature request.
By design we limited the packet capture to the first 110 bytes. All A1 version will only capture the first 110 bytes.
Apparently this limitation was removed in A2.
It's good to know anyway.
