Cisco 1131 Cannot Associate to WLC Following WCS Install
Aug 6th, 2008
Greetings, i have had a small wireless deployment up and running for several months consisting of 3 1131 and a 1242 lightweight ap's registered with a 2106 WLC.
Ive had no problems up until i installed WCS on a separate server for testing, ive added the controller successfully and can see all access points up until a day ago.
Following a re-boot of one of our PoE switches two of the 1132 access points failed to re-register with the controller whilst the other two ap's reconnect without issue.
On the Ap themselves lwapp comes with then goes into cfg mode but fails to pull down the config of the controller and then resets.
The controller is giving the message for one of the Ap's
Aug 06 18:03:34.861 spam_lrad.c:2286 LWAPP-3-RD_ERR4: Invalid regulatory domain 802.11bg:-E 802.11a:-E for AP 00:1d:e5:55:df:1a
Previous message occurred 3 times.
Aug 06 18:03:34.861 spam_lrad.c:8055 LWAPP-3-RD_ERR7: Invalid country code () for AP 00:1d:e5:55:df:1a
I have tried resetting both ap's using the mode button at power on but cant figure out what is causing the issue.
Any help would be appreciated!
Scott Fella Wed, 08/06/2008 - 19:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The error states that the country code for the ap is not the same as configured on the wlc. Look at the model number and find out what the country it is manufactured for and then add that to the country code on the wlc. That should fix your issue.
exonetinf1nity Thu, 08/07/2008 - 00:31
Thank you for your response except all the Ap's were working prior to this issue and all are ETSI.
exonetinf1nity Thu, 08/07/2008 - 01:21
This is the response im getting, for some reason its trying to use an external DNS server as the controller.
cisco AIR-LAP1131AG-E-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1213Q1Z8
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 5.1.151.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:7A:BE:63:60
Part Number : 73-8962-12
PCA Assembly Number : 800-24818-11
PCA Revision Number : B0
PCB Serial Number : FOC12112BWJ
Top Assembly Part Number : 800-29144-02
Top Assembly Serial Number : FCZ1213Q1Z8
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-E-K9
The name for the keys will be: AP001e.7abe.6360.cisco.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
Press RETURN to get started!
*Mar 1 00:00:05.639: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:05.846: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 45 messages)
*Mar 1 00:00:07.931: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:09.699: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(16b)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 07-Jul-08 18:08 by prod_rel_team
*Mar 1 00:00:09.700: %SNMP-5-COLDSTART: SNMP agent on host AP001e.7abe.6360 is undergoing a cold start
*Mar 1 00:00:09.745: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:27.341: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:27.344: bsnInitRcbSlot: slot 0 has NO radio
*Mar 1 00:00:27.344: bsnInitRcbSlot: slot 1 has NO radio
*Mar 1 00:00:27.362: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Mar 1 00:00:27.362: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar 1 00:00:27.868: Logging LWAPP message to 255.255.255.255.
%DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 172.29.255.51, mask 255.255.255.0, hostname AP001e.7abe.6360
Translating "CISCO-LWAPP-CONTROLLER.********************.local"...domain server (172.29.255.25) [OK]
%LWAPP-3-CLIENTEVENTLOG: Did not get vendor specific options from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
%LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER..********************..local
%LWAPP-3-CLIENTEVENTLOG: Controller address 208.69.34.132 obtained through DNS
%CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
%LWAPP-5-CHANGED: LWAPP changed state to JOINEncoding the APType as 0
Encoding the RSSI threshhold as 0
%LWAPP-5-CHANGED: LWAPP changed state to CFG
Writing out the event log to nvram...
%LWAPP-3-CLIENTERRORLOG: Config Request Timer: did not recieve config response (controller - it-wlc-2106)
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE.
%LWAPP-5-CHANGED: LWAPP changed state to DOWN
exonetinf1nity Thu, 08/07/2008 - 01:32
This is the response im getting when i add a DNS entry for the lwapp controller into DNS.
*Mar 1 00:00:05.344: soap_prepare_new_image_crash: mini ios flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx
*Mar 1 00:00:05.345: set boothlpr to mini ios
*Mar 1 00:00:05.697: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:05.904: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 53 messages)
*Mar 1 00:00:07.990: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.992: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:11.955: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:11.956: %SNMP-5-COLDSTART: SNMP agent on host AP001e.7abe.6360 is undergoing a cold start
*Mar 1 00:00:12.001: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:27.743: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:27.745: bsnInitRcbSlot: slot 0 has NO radio
*Mar 1 00:00:27.745: bsnInitRcbSlot: slot 1 has NO radio
*Mar 1 00:00:27.763: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Mar 1 00:00:27.764: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar 1 00:00:28.272: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-LWAPP-CONTROLLER..********************..local"...domain server (172.29.255.25) [OK]
%LWAPP-3-CLIENTEVENTLOG: Controller address 172.29.255.5 obtained through DNS
exonetinf1nity Thu, 08/07/2008 - 01:33
This is the lwapp debug output of the controller, i have the regulatory domain set for GB on the controller and these access points match that domain?
*Aug 07 10:29:37.113: Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6,joined Aps =2
*Aug 07 10:29:37.113: 00:1d:e5:55:df:1a Successful transmission of LWAPP Discovery Response to AP 00:1d:e5:55:df:1a on port 1
*Aug 07 10:29:47.560: 00:1f:9d:23:90:f0 Received LWAPP ECHO_REQUEST from AP 00:1f:9d:23:90:f0
*Aug 07 10:29:47.560: 00:1f:9d:23:90:f0 Successful transmission of LWAPP Echo-Response to AP 00:1f:9d:23:90:f0
*Aug 07 10:29:48.120: 00:1d:e5:55:df:1a Received LWAPP JOIN REQUEST from AP 00:1d:e5:55:df:1a to 00:1e:be:96:4f:80 on port '1'
*Aug 07 10:29:48.120: Received a packet which is a (type = JOIN_REQUEST) with session id 0
*Aug 07 10:29:48.133: 00:1d:e5:55:df:1a AP it-ap-1131-01: txNonce 00:1E:BE:96:4F:80 rxNonce 00:1D:E5:55:DF:1A
*Aug 07 10:29:48.133: 00:1d:e5:55:df:1a LWAPP Join Request MTU path from AP 00:1d:e5:55:df:1a is 1500, remote debug mode is 0
*Aug 07 10:29:48.133: DTL Adding AP 4 - 172.29.255.51
*Aug 07 10:29:48.134: 00:1d:e5:55:df:1a Successfully added NPU Entry for AP 00:1d:e5:55:df:1a (index 4)
Switch IP: 172.29.255.6, Switch Port: 12223, intIfNum 1, vlanId 101
AP IP: 172.29.255.51, AP Port: 24049,
*Aug 07 10:29:48.836: 00:1d:e5:55:df:1a Successful transmission of LWAPP Join Reply to AP 00:1d:e5:55:df:1a
*Aug 07 10:29:48.836: 00:1d:e5:55:df:1a spam_lrad.c:1589 - Operation State 0 ===> 4
*Aug 07 10:29:48.837: 00:1d:e5:55:df:1a Register LWAPP event for AP 00:1d:e5:55:df:1a slot 0
*Aug 07 10:29:48.837: 00:1d:e5:55:df:1a Register LWAPP event for AP 00:1d:e5:55:df:1a slot 1
*Aug 07 10:29:50.819: 00:1d:e5:55:df:1a Received LWAPP CONFIGURE REQUEST from AP 00:1d:e5:55:df:1a to 00:1e:be:96:4f:80
*Aug 07 10:29:50.819: 00:1d:e5:55:df:1a AP 00:1d:e5:55:df:1a: Invalid country code ().
*Aug 07 10:29:50.819: spamVerifyRegDomainSlot: AP 00:1d:e5:55:df:1a(slot 0) unsupported radio type 0XFF.
*Aug 07 10:29:50.819: spamVerifyRegDomainSlot: AP 00:1d:e5:55:df:1a(slot 1) unsupported radio type 0XFF.
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a AP 00:1d:e5:55:df:1a: Invalid country code ().
*Aug 07 10:29:50.820: spamVerifyRegDomainSlot: AP 00:1d:e5:55:df:1a(slot 0) unsupported radio type 0XFF.
*Aug 07 10:29:50.820: spamVerifyRegDomainSlot: AP 00:1d:e5:55:df:1a(slot 1) unsupported radio type 0XFF.
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a Updating IP info for AP 00:1d:e5:55:df:1a -- static 0, 172.29.255.51/255.255.255.0, gtw 172.29.255.1
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a Updating IP 172.29.255.51 ===> 172.29.255.51 for AP 00:1d:e5:55:df:1a
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a AP 00:1d:e5:55:df:1a not allowed to join. Regulatory Domain check failed.
Allowed regulatory domain: 802.11bg:-E 802.11a:-E
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1d:e5:55:df:1a slot 0
*Aug 07 10:29:50.820: 00:1d:e5:55:df:1a apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1d:e5:55:df:1a slot 1
*Aug 07 10:29:50.820: DTL Deleting AP 4 - 0.0.0.0
Trending Topics - Security & Network
