Call Manager Express on a 2801
Aug 6th, 2008
Im new to cme and need help
I just picked up a Cisco 2801 yesterday and want to get a little understanding about the PVDM cards.
I would like to setup CME on it and run a small test lab but Im not sure what the requirement for CME do I need a PVDM??? and if so what is a cheap PVDM that will do the trick?
I will need to get the CME IOS and PVDM correct?
Brandon Buffin Thu, 08/07/2008 - 07:26
  • Purple, 4500 points or more
You will need the IOS with CME capabilities. The PVDM you need will depend on the voice interfaces you have - T1/E1, FXO, etc. You can use the DSP calculator to calculate the number of DSPs required for your configuration.
http://www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
Hope this helps. If so, please rate the post.
Brandon
