ASA5550 Active/Active or Active/Standby
Aug 6th, 2008
Hi what is best practise for confirguring asa5550 failover. Please can i have some advise as at the moment we have pix525 with failover stateful which works well for us. But i have been reading and active/active seems attractive, but not sure. As this is something different. Please can you also post a configuratin of the recommended solution
dhananjoy chowdhury Wed, 08/06/2008 - 12:41
  • Silver, 250 points or more
Active/Active failover is only available to ASA/PIX firewall in multiple context mode.
Now if you configure FW in context mode features like VPN, Dynamic routing protocols, Multicast, etc. are not supported.
So, before migrating to Active/Active failover, you should check your requirements.
network_team Wed, 08/06/2008 - 12:47
Hi Thanks...
Can you send me a sample config for Active/Standby for asa5550. I dont want to loose functionality within the unit. What is the best active/stanby setup? is it stateful and how do i configure it. I have configured the pimary unit, but im confused on the setup for failover and what configuration is needed for the secondary ?
Cheer lev
JORGE RODRIGUEZ Wed, 08/06/2008 - 14:04
  • Green, 3000 points or more
In addition to Dhananjoy info.
Read this link for Stateful failover configuration detail information and implementation options. pease read the whole part (configuring failover) almost cover every question you may have.
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/failover.html#wp1051759
You would want to have stateful enable and take advantage of feature,you may use the same regular LAN base port for statefull,go over the stateful link above.
Last but not least , take a tour in this link for interactive ASA active/standby config training even though is a agraphical presentation it will help you alot.
Interactive- Pick Active/Standby Failover for ASA 5500
http://www.cisco.com/web/learning/le31/le29/configuring_asa_pix_security_appliances.html
Rgds
Jorge
network_team Thu, 08/07/2008 - 03:30
Thanks this is excellent...
Just one more question When primary pix goes down and secondary is now active. Can you make changes to secondary and will it replicate up to primary ? when sync starts
network_team Thu, 08/07/2008 - 05:20
Hi I have configure primary asa with a full config. what configurations apart from the failover information do i configure. Do i configure the same ip address on the interfaces as the primary
dhananjoy chowdhury Thu, 08/07/2008 - 05:27
This is all is reqd on the Secondary box. Check the cables are connected.
failover lan unit secondary
failover lan interface failover Ethernet3
failover lan enable
failover key ******
failover interface ip failover 10.1.0.1 255.255.255.0 standby 10.1.0.2
failover
network_team Fri, 08/08/2008 - 01:22
Excellent Thanks this now works, but i have one concern. I get a 1 milisecond time out when i failover occurs. I feel this will affect connectivity for users. Should i be concerned
I have configured the following:
interface GigabitEthernet1/3
description LAN/STATE Failover Interface
speed 1000
duplex full
failover
failover lan unit Primary
failover lan interface Fail GigabitEthernet1/3
failover replication http
failover link Fail GigabitEthernet1/3
failover interface ip Fail 221.0.0.1 255.255.255.252 standby 221.0.0.2
failover
