ACS 4.2 - Can it do this
Aug 6th, 2008
We have some access points that are on carts at a client. When they connect the access point to a port they will make sure it is in the correct vlan for the management ip of the access point. My question is can the ACS say that any users who connect to a certain AAA client will be tagged with a certain vlan and thus get a dhcp in that range. Can the ACS define an address pool per AAA client to give to the clients?
Marwan ALshawi Wed, 08/06/2008 - 21:02
sure it is posible
either in the gorup level or user level
u can assign vlan, address pool or even static ip per user
check it in user setteing on the ACS
also "AV pairs"
good luck
please, if helpful Rate
