Marwan ALshawi Thu, 08/07/2008 - 19:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
only IOS enough
PVDM used with its DSPs for transcoding MTP and conferenceing resources
if u wanna do like confrenceing
u need DSP resources
each confrence need DSP
but for nromal CME without PVDM u can practce alot of features and u can say most of the features
good luck with ur lab
please, if helful rate
don-sullivan Fri, 08/08/2008 - 10:56
Cisco IOS Versions 12.4.15T4 through 12.4.15T6 being the lastest. Use the archive command to place the CCME html files in FLASH:/GUI.
If you only plan to use SCCP Cisco phone or the Cisco IP softphone no PVDM is required. If you plan on using mulitple voice protocols then you'll need it.
