Answered Question
Aug 6th, 2008
Hi there;
If a swtich/router has a USB port, is it possible to get a script onto a switch/router from a USB stick?
Correct Answer by Mark Yeates about 8 years 2 months ago
Yes, depending on which USB port you are using it would be usbflash{0-9}: Your syntax is correct to copy the running config to usbflash. Here is even more information on using flash drives.
Overall Rating: 5 (1 ratings)
austindaz Wed, 08/06/2008 - 15:35
Hi there;
Would the command be 'copy run usbflash:' or something of that nature? I'm trying to work it out before I get to site.
austindaz Wed, 08/06/2008 - 15:54
thanks very much. I'll give it a go when I get to site
