08-06-2008 07:38 PM - edited 03-15-2019 12:28 PM
I am configuring the CME to enable conferencing. I get <0-0> when I try to configure max sessions, which means I can't have conferencing. I have enough DSPs. Please see the below (truncated) config.
voice-card 0
dspfarm
dsp services dspfarm
no local-bypass
tftp-server flash:apps41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
sccp local FastEthernet0/0.2
sccp ccm 10.4.3.1 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register transcode
associate profile 1 register mtp001d70103e30
keepalive retries 5
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
telephony-service
sdspfarm units 1
Appreciate if someone could help me out.
Thanks.
Solved! Go to Solution.
08-06-2008 07:40 PM
I would tend to say you do not have enough DSP's. What DSP modules are in the router and what cards are in the router. sh tech please.
Chad
08-06-2008 07:40 PM
Chad
08-06-2008 08:10 PM
i have to agree with Chad most probably not enough DSPs, if possible also post the sh run.
rememember, conferencing takes a WHOLE dsp
ie: if you have 15 channels to spare... that won't do since you need the whole 16 channels
issue a sh voice dsp to see how many channels are already allocated
java
if this helps, please rate
