Chad Stachowicz Wed, 08/06/2008 - 21:12
  • Silver, 250 points or more
no it is not, slips are from misconfigured clocking, and should be at 0.
can you explain your situation so we can help you clock it?
HTH,
Chad
bschear Thu, 08/07/2008 - 05:23
They have a site to site data T1 and voice PRI coming into the router. Here is config info etc.
T1 0/1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: PRI Circuit
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060623, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (335 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
24 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
24 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 37 15 minute intervals):
2 Line Code Violations, 2 Path Code Violations,
2435 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
2435 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 12 Unavail Secs
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI Circuit
interface Serial0/0/0
bandwidth 1544
ip address 192.168.3.2 255.255.255.252
encapsulation ppp
no ip mroute-cache
service-module t1 timeslots 1-24
service-policy output VOICE-POLICY
interface Serial0/1/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address .* plan isdn type unknown
no cdp enable
Rajesh Revuru Thu, 08/07/2008 - 06:54
Hello:
You have to check the network clocking. Do "show network"
Slip seconds are usually caused because of clocking b/n router and carrier. Slip secs will result in poor voice quality.
Ayodeji Okanlawon Thu, 08/07/2008 - 07:19
  • Cisco Designated VIP,
    2017 IP Telephony
Usualy this is due to inproper clocking configuration..
You need to have these lines in your config.
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0 ..
You should configure to suit your controller slot numbers...
