MPF configuration..
Aug 6th, 2008
In MPF how many service-policy I can configure per interface.Please find theconfiguration in my ASA..
class-map inspection_default
match default-inspection-traffic
class-map imblock
match any
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map type inspect im impolicy
parameters
match protocol msn-im yahoo-im
drop-connection
policy-map IM_BLOCK
class imblock
inspect im impolicy
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
service-policy global_policy global
service-policy IM_BLOCK interface outside
I want to add one more modular policy to prevent TCP SYN attack.Please find the configuration..
#class-map tcp_syn
#match port tcp eq 80
#exit
#policy-map tcpmap
#class tcp_syn
#set connection conn-max 100
#set connection embryonic-conn-max 200
#set connection per-client-embryonic-max 10
#set connection per-client-max 5
#set connection timeout embryonic 0:0:45
#set connection timeout half-closed 0:25:0
#set connection timeout tcp 2:0:0
#exit
#service-policy tcpmap global
** Shall I add the above configuration in my ASA?How many service policy I can assign in global interface.
Overall Rating: 4 (2 ratings)
dhananjoy chowdhury Wed, 08/06/2008 - 21:23
You can apply only one Global policy, which will do inspection on all interfaces.
You can either modify the global policy or create your own policy and apply globally or to one or more interfaces.
somnath21 Wed, 08/06/2008 - 21:35
Thanks!!
Can I do like this..
Configure a separate class-map (tcp_syn) and add it under the policy-map global_policy (default).
class-map tcp_syn
class tcp_syn
Please assist..
Marwan ALshawi Wed, 08/06/2008 - 21:41
u cam have one global policy
and on policy per interface
the interface policy override the glbal one if overlaped
in ur question the conifg ok
but i see u put ur config under the default global policy
why u applying another on??
once u put the config under the global_policy which is the defaul one it will be automaticly applied globaly
good luck
please if helpful rate
dhananjoy chowdhury Wed, 08/06/2008 - 21:52
Yes you can add new class-map.
But don't add this "service-policy tcpmap global"
You can have only one policy in the global.
somnath21 Wed, 08/06/2008 - 22:07
Please find my configuration...
Lines started with * are newly added.
class-map imblock
match any
*class-map tcp_syn
*match port tcp eq 80
parameters
parameters
drop-connection
policy-map IM_BLOCK
class imblock
inspect im impolicy
*class-map tcp_syn
*set connection conn-max 100
*set connection embryonic-conn-max 200
*set connection per-client-embryonic-max 10
*set connection per-client-max 5
*set connection random-sequence-number enable
*set connection timeout embryonic 0:0:45
*set connection timeout half-closed 0:25:0
*set connection timeout tcp 2:0:0
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
It's ok na??
dhananjoy chowdhury Wed, 08/06/2008 - 22:36
this seems ok.
Just for confirmation can you post the last part of the running-config
- starting from " policy-map global_policy"
till the statement "service-policy IM_BLOCK interface outside "
somnath21 Wed, 08/06/2008 - 22:47
My current MPF configuration..
class-map imblock
match any
parameters
parameters
drop-connection
policy-map IM_BLOCK
class imblock
inspect im impolicy
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
I want to add (*) these lines..
*class-map tcp_syn
*class-map tcp_syn
*set connection conn-max 300
*set connection embryonic-conn-max 400
*set connection per-client-max 15
dhananjoy chowdhury Wed, 08/06/2008 - 23:05
Hi Somnath,
Do it like this..
myPIX(config)# class-map tcp_syn
myPIX(config-cmap)# match port tcp eq 80
myPIX(config-cmap)# exit
myPIX(config)# policy-map global_policy
pixfirewall(config-pmap)# class tcp_syn
pixfirewall(config-pmap-c)# set connection conn-max 100
..... and so on....
somnath21 Wed, 08/06/2008 - 23:17
One more help,If I configure like the above one it will be applicable for only port 80.
I want to connection limit for all traffic.
The below configuration is ok or not?
myPIX(config-cmap)# match any
*class-map tcp_syn
*set connection conn-max 700
*set connection embryonic-conn-max 1200
*set connection per-client-embryonic-max 20
*set connection per-client-max 10
The parameter mentioned above like
conn-max 700,
embryonic-conn-max 1200,
per-client-embryonic-max 20,
per-client-max 10
are ok or not?
dhananjoy chowdhury Wed, 08/06/2008 - 23:35
Only a small change....
class tcp_syn
..... and so on.
If you do as per below your purpose is not solved.
class-map tcp_syn
somnath21 Wed, 08/06/2008 - 23:58
I want to configure that one to prevent Dos attack (TCP SYN).
Is it possible by limiting port 80 traffic or I have to go for any.
somnath21 Thu, 08/07/2008 - 03:11
sorry one more confusion..
if I configure like that then it will be applicable for all traffic or individual.
I want to meant it will limit total connection to 900 or each connection (FTP-900,HTTP-900 like that
) to 900.
class-map tcp_syn
match any
class tcp_syn
set connection conn-max 900
set connection embryonic-conn-max 300
Marwan ALshawi Thu, 08/07/2008 - 03:21
because in ur class-map
u have match any
then this will consider the total amount of connections as 900
if u want to restrect only one typ lets say http
do :
access-list 100 permit tcp [source IPs] [netmask] [any or destination IP with mask] eq 80
access-list 100 permit tcp [source IPs] [netmask] [any or destination IP with mask] eq 443
then
make new class
class-map http-map
match access-group 100
then
apply it the same way u have don above
