Removing a vlan from vlan group in FWSM
Aug 6th, 2008
I have following vlan groups assigned to FWSM in 6500 and it is production;
firewall vlan-group 1 100,200,400,800
Now I want to remove just VLAN 800 from the group. If I enter the command;
no firewall vlan-group 1 800
will it affect the traffic in other vlan s? I want to know this from someone whoi has done it practically, becase the traffic in other segnemnts are really critical, and I want zero disturbance for them.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Wed, 08/06/2008 - 21:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
why it affect traffic in other vlans?
unless other vlans have comunications with this one
like nating or routing
Farrukh Haroon Wed, 08/06/2008 - 22:57
  • Red, 2250 points or more
Do you mean will "no firewall vlan-group 1 800" remove the other vlans from the vlan-group 1? Then the answer is NO!, your show run will become:
If you mean affect in the literal sense, then only you can tell that. Pretty difficult to tell you that by seeing only one line in your ocnfig :)
Farrukh
