Can't add ASA in CSM 3.1.1 when WEBVPN enabled
Aug 6th, 2008
Hi Friends,
I have ASA5510 enabled with Web VPN access and when I try to add the ASA 5510 in Cisco security Manager 3.1.1 console it fails.
Can anyone help me to resolve this issue.
Overall Rating: 4 (2 ratings)
Farrukh Haroon Thu, 08/07/2008 - 06:16
Which version of the ASA?
I think they have some limitations there when it comes to SSL VPN, ASA 7.x with CSM 3.1.x and 8.x with 3.2.x only (Something like this).
ckuriyar74 Thu, 08/07/2008 - 22:09
The ASA version is 8.0(3) and CSM software 3.1.1
Iam able to add these ASA boxes in RME but unable to import from DCR in cisco security manager.
It fails to add the device and i suspect could be the device is unable to contact via https because webvpn is used this port.
any possible solutions to resolve this issue?
Farrukh Haroon Thu, 08/07/2008 - 23:33
However remember the earlier Caveat I mentioned:
What's New in Security Manager 3.2.1
•Support for ASA 8.0 and 8.1 SSL VPN configurations. Support for SSL VPN on ASA 7.x is removed in Security Manager 3.2.1. The Security Manager 3.2.1 installer provides a warning if any ASA 7.x SSL VPN configurations are detected in the case of an upgrade.
ckuriyar74 Tue, 08/12/2008 - 01:36
I tried changing ports for both ASDM and WEbVPN.
Now I could able to import the ASA in CSM.
