Fallback: Bypass Radius Server
Aug 6th, 2008
Hi guys,
Currently checking zeroshell for radius to centralize my logins. My question is, if the radius server fails, is there a fallback username/password that i can configure just in case?
Thanks.
Overall Rating: 5 (1 ratings)
yjdabear Thu, 08/07/2008 - 06:20
You can configure IOS to try multiple RADIUS/AAA servers. It's always a good idea to have more than one.
aaa group server radius authentication-group
server 209.165.200.225 key radkey1
server 209.165.200.226 key radkey2
aaa group server radius accounting-group
server 209.165.201.1 key radkey3
Or, if you meant configuring a local user/password on the router, check out
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ft_md5.html
username name secret {[0] password | 5 encrypted-secret}
jeffersoncbriones Thu, 08/07/2008 - 17:38
Let say my routers are configured to authenticate tru the radius server. What if that radius server goes down, how can i telnet/ssh into my router then? Thats why im finding a way wherein login should first be authenticated tru the radius server and if no radius server found (radius is down) a backdoor username/password can be used.
Thanks.
Richard Burts Fri, 08/08/2008 - 12:40
Jefferson
It is a very common requirement to have some backup method of authentication such as local authentication in case the configured server (or multiple servers) is not available. Assuming that you have the radius server configured you would want something like this in your config:
user password
aaa authentication login default group radius local
This will attempt to authenticate with radius and if there is an error in that authentication attempt then it will authenticate with the configured local user ID and password.
Rick
