QoS urgent
hai
I am working for an ISP so that i have put a 2 MB link to the customer router . since the customer is having video traffic i had pu t some policies in the customer end router .i had given precedence value 4 for the video traffic and remaining in class-default,after applying the policy map to the outside port(which is connected to the ISP) the availiable banwidth is showing 0 and getting the packet queued.the queing stratagy showing is weighted fair .so i tried to make it as fifo thru "no fair-qeue" then it is given that "must disable the CBWFQ"
I had given priority 1536 for video and remainin 512 MB for data
please help me to clear this problem
thanks in advance
Mahesh
royalblues Thu, 08/07/2008 - 00:59
  • Green, 3000 points or more
This is not a problem.. since you are using CBWFQ and have assigned all available bandwidth to the policy, the show interface would show it as zero
You need to use sh policy-map interface to see whether you are dropping traffic under the class
Narayan
nourelrayes Thu, 08/07/2008 - 21:44
LLQ should be used when there is real time applications, it will give the video application a fixed strict bandwidth queue.
LFI also should be used to decrease the seialization delay.
Only 75% of the total availble bandwidth should be assigned to the classes created.
shiva_ial Mon, 08/11/2008 - 02:28
mahesh,
I suggest you should do some modifications on the policy applied
as per your policy
voice class - 1548 kbps
data class - 512 kbps
totally accounts around 2048 kbps (2MB link)
you should understand,until you use max-reserved bandwidth command in the interface config you will have only 75% of bandwidth allocated to the policy which is 1.5 mbp approximately.
75% is cisco's recommendation(remaining 25% is used for routing & other protocol updates)
so you should have used max reserved bandwidth command to override this and use 2mb completely.
I hope,have answered you query.
rate if it helps
rgds/shiva
