can not delete "ip host-routing" command from Switchconfig
Aug 7th, 2008
i have a WS-C3750G-12S with IOS Ver. 12.2(35)SE5, IPBASE.
In its config it has the command "ip host-routing" which i tried to delete several times without success.
A "no ip host-routing" command gives no error but it does not do what i think it should.
Does anybody know about this ?
regards
Joerg
itdsmartnet Thu, 08/07/2008 - 01:34
hello,
you should reload your switch. it will solve your issue.
