call manager express voice translation rules help !!!!
Aug 7th, 2008
We have a cme on cisco 2811 router.
we need voice translation rules setup for 30 numbers.
the provider sends the full number into us so for example 016520547 for the main number and the example number of the main office phone is 2234. in cme it only allows a maximum of 15 rules in each voice translation, how do i setup around 35 or 40 rules as i cant see a wildcard to work with this. under the voice translation profile we can only assign a single translate called or calling and then in the dial-peer for the SIP trunk we can only use a single transation profile as well.
any ideas?
Marwan ALshawi Thu, 08/07/2008 - 01:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
can u tell me what u want to achive exactly and with more detailed example
because we might solve it with diffrent wany not pnly translation-rul
thank you
cmelbourne Thu, 08/07/2008 - 02:39
hi,
basically we have a SIP trunk to a service provider (VOIP).
we have an IP Phone with an extension number of 2234. the DDI number for this for outgoing and incoming calls needs to be 016520547
this would be fine if it was only a few phones like this and we could then just make a rule like below
voice translation-rule 1
rule 1 \2234\ \016520547\
however if you do this then you can only have 15 or 16 rules in the voice translation rule itself and we have around 40 ip phones i think each with there own extension number 22xx and each with there own ddi number all starting with 0165205xx
do you know of any way we can do this.
the service provider carries the full ddi number into our system.
so if we use a rule for each ip phone that would be fine but it only allows 1-15 rules.
we only have a single dial-peer
see below details of config.
rule 1 /016520540/ /2234/ (this only allows 16 rules)
voice translation-rule 2
rule 1 /2234/ /016520540/ (this only allows 16 rules)
voice translation-profile ddi-map
translate called 1
voice translation-profile out-ddi
translate calling 2
dial-peer voice 200 voip
description SIP TRUNK
translation-profile incoming ddi-map
translation-profile outgoing out-ddi
service ses
max-conn 4
destination-pattern .T
session protocol sipv2
session target ipv4:8x.xx.xx.xx
session transport udp
dtmf-relay sip-notify rtp-nte
codec g711ulaw
clid network-provided
Marwan ALshawi Thu, 08/07/2008 - 03:08
u can achive it in several ways
i have just tested the followinf for u
make number exapntion for incoming calls and a translation rul for out going calls that translate ur ip phon calling number to apear as DID
for example let say a call came to 016520533
will be chamged to 2233 and forwarded to that number
and if for example phon 2244 mad a call his number will apear as 016520544
the config as bellow
num-exp 0165205.. 22..
verification:
Router#show dialplan number 016520533
Macro Exp.: 2233
No match, result=-1
and do the following translation
and make a translation profile for CALING
and apply it to ur outgoing dial-peer
rule 1 /22\(..\)/ /0165205\1/
verfication:
Router#test voice translation-rule 1 2233
Matched with rule 1
Original number: 2233 Translated number: 016520533
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
i think this will solve ur problem
if u have any more questions just post it here
good luck
please, if helpful rate
cmelbourne Thu, 08/07/2008 - 03:01
hi,
will give this a go.
do i need to take out all the voice translation rules now and do i need to assign the num-exp to a particular dial peer for outbound and inbound rules?
Marwan ALshawi Thu, 08/07/2008 - 03:40
do the config i have sent u and mostly will work
and about num-exapantion
do it in global config mode
no in any dial peer
and u have to have default incomfing dial-peer
letssay voip dial peer with the SIP
config for ur company
dhould contain somthing like
destination-pattren [the DID]
incoming-called number .
the incoming called number witht he dot will match any incoming number[ called defualt incomin dial perr]
for example
translation-profile outgoing out-ddi [ replace this outgoing with the one i sent u also outgoing ]
service ses
max-conn 4
incoming called-numer .
codec g711ulaw
if u want u can use incoming translation profile for the 1 phon u had already but for all other phones do as the sent config
good luck
cmelbourne Thu, 08/07/2008 - 03:55
hi,
thanks but that example wont work
see below the extensions and ddi numbers
ext no. ddi no.
2234 016520540
2235 016520541
2236 016520542
etc....
can we not get rid of the voice translation rules and just use num-exp instead?
Marwan ALshawi Thu, 08/07/2008 - 04:28
avoid the translation things now and try the following command on each DN number config it self
lets say ur DN 4 has the following:
ephone-dn 4 dual-line
number 2234 secondary 016520540 no-reg both
and let me know
good luck
Marwan ALshawi Thu, 08/07/2008 - 04:48
be careful from any conflicting num-expantion or translation
this will creat a vitualt voice port for the seconday number
so will be useful for ur case
i mean the sondary number
cmelbourne Thu, 08/07/2008 - 04:48
hi
i will try this when the service provider has brought up the link again, they have took it down at the minute.
does the number 2234 secondary 016520540 no-reg both mean that the ip phone is 2234 and the ddi number is 016520540 without using any voice translation or num-exp commands?
Marwan ALshawi Thu, 08/07/2008 - 04:51
this will associate a virtual port with that number with this DN and any ip phon use this DN will use this virtual port
so any call to the 2234 or 016520540 will go to that ip phon with that dn
Marwan ALshawi Thu, 08/07/2008 - 16:39
did u try it ?
cmelbourne Fri, 08/08/2008 - 01:20
hi,
that worked perfectly.
i have a secondary dialtone which is 9 for an outside line but the VOIP Provider has said we need to strip this as the number they are getting from us is 901xxxxxxx
what is the voice translation rule to strip the 9 for outgoing calls and keep the rest of the number the same
dezoconnor Fri, 08/08/2008 - 02:04
  • Silver, 250 points or more
Hi, I would say that you don't need to create a translation-pattern to strip the 9. You can do this on the outbound SIP dial-peer:
service ses
max-conn 4
On the destination-pattern use 9.T so whenever users dial 9 it will be matched and stripped.
Marwan ALshawi Fri, 08/08/2008 - 02:17
THIS IS VOIP DIAL PEER NOT POTS
what u said apply on POTS dial PEERs
unless he use forward digit 6
while the six digits will count from right to left
6 for example u can put any number u want
Marwan ALshawi Fri, 08/08/2008 - 02:09
i am glad its working :)
for that case do the following translation
make the profile for called number then
apply it on the outgoing direction
the translation rule as:
rule 1 /9\(01......\)/ /\1/
while u can add or remove from the DOTs based on the number of digits u have
this is the verification of the rule
Router#test voice translation-rule 1 901234567
Matched with rule 1
Original number: 901234567 Translated number: 01234567
good luck
please, dont forget rate the helpful pots
