Auto QOS on Catalyst 3560G for Cisco IP Phones
shaw.chris
Can you please tell me the command I should be using for the interfaces where my IP phones are to be connected,
I'm unsure if it should be
auto qos voip cisco-phone
or
auto qos voip trust
or both?
Also does the trunk link to the CME router need to have these commands applied?
Chris
Marwan ALshawi
on the port connected to the ip phone:
the above comman Enable auto-QoS on the interface, and specify that the interface
is connected to a Cisco IP phone.
The QoS labels of incoming packets are trusted only when the
Cisco IP phone is detected.
on the turnk between swithc to switch or switch to router:
auto qos voip trust
this command Enable auto-QoS on the interface, and specify that the interface
is connected to a trusted router or switch
Please, if helpful Rate
Many Thanks,
I have a crossover cable going from the switch into a different vendor switch, for this port would I need to put in "auto qos voip trust"?
