08-07-2008 02:51 AM - edited 03-03-2019 11:03 PM
Hi all,
What is route-Map ,How we configure in Cisco routers,Pls Provide with Practical scenario,It is urgent,I am Implementing today only,Pls provide inputs
Tnks
Ramu
CMC ltd
08-07-2008 03:01 AM
What is the purpose you want to use route-maps for ?
Here is an example for Policy Based routing with route-map.
08-07-2008 03:03 AM
A route-map is a very powerfull tool that can be used for a number of purposes, mainly it is used for route-filtering, when perhaps redistributing from one protocol into another, ie ospf into bgp, and you only want some of the routes to be redistributed.
You can also use the route-map to do policy based routing, which allows you to manipulate traffic flow based on source ip address example.
Additionally route-maps can also be used in NAT scenarios when you want to specificy which source ip addresses should be NAT'd.
Check out;
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1015665
LR
