LMS - installed, inactive, active ports
Answered Question
Aug 7th, 2008
I'm a lms-beginner and want to get these Informations from discovered devices
installed ports of all switches / all routers
active/inactive (free) ports of switzches and routers.
there are so many features and I don't know, if I can get the information and where can I get it - need a lot of help in future - thanks - Arne
Correct Answer by Joe Clarke about 8 years 9 months ago
Then you can use the Switch Port reports in Campus Manager to get what you want. Go to Campus Manager > User Tracking > Reports > Report Generator, and select either the Switch Port Capacity Report or the Switch Port Summary report. The latter will tell you all of your current port usage where as the former will show you at what percentage of capacity your devices currently are.
Overall Rating: 4 (1 ratings)
Joe Clarke Thu, 08/07/2008 - 07:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of LMS do you have?
Correct Answer
Joe Clarke Thu, 08/07/2008 - 22:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
