VPN and VLAN
Aug 7th, 2008
I have a problem with a VPN L2L between a pix 506 and a ASA 5510. Behind the ASA, I have 6 VLAN, and behind the PIX, 1 network. In order to create the tunnel, I ping (with a server behind the ASA, in the server VLAN for example) a server behind the PIX. But I can't create the tunnel when I ping (with a server behind the pix) an equipment in one VLAN behind the ASA. Do you know why? A problem with a route?
Thank you
Farrukh Haroon Thu, 08/07/2008 - 11:17
  • Red, 2250 points or more
It could be tons of reasons. Do you mean to say that if tunnel is initiated from the ASA LAN it works, but it DOES NOT when you do so from behind the PIX? Is that the case?
Can you post your configs?
Farrukh
