Warning message
6509 with SUP2 problem
Aug 7th, 2008
I have a client that purchased a SUP2 w/ MSFC2 and a 6509 chassis. He is complaining of very long load times for the show run and write memory commands. This begins several hours after reload. I told him to eliminate the flash and RAM as the culprit by process of elimination. I was wondering if anyone had seen symptoms like this before. He is running IOS (tm) c6sup2_rp Software (c6sup2_rp-PK9SV-M), Version 12.2(18)SXD6. Thank You.
Will
Jerry Ye Thu, 08/07/2008 - 13:07
  • Cisco Employee,
Hi Will,
It is really depend on how big is the config and how busy is the CPU. If you have a really large config, "show run" will take some time. Same thing apply to a really busy switch.
You can verify it with "show proc cpu" and "show run | i bytes".
HTH,
jerry
