Qos On the switchport connected to PIX
Aug 7th, 2008
Hi all,
How can I enable QOS on the accessport connected to the PIX to restrict the traffic that people are doing it when downloading to lets say 50k?
Marwan ALshawi Thu, 08/07/2008 - 07:34
class-map class1
match any
policy-map policy1
class class1
police 128000 8000 confirm-action transmit exceed-action drop
interface fa1/1
service-policy output policy1
the above example will match all network traffic with match any in the class map then will pemir maximum of 128K or traffic any traffic above that will be droped
and apply to the switch interface in the outbound direction
in the case if this is ur switch interface connected to the firewall it will send maximum of 128K to the firewall through that port
good luck
please Rate if helpful
TcsHungary Thu, 08/07/2008 - 07:36
All right ,
Thanks I will do this , but now will this affect my VPN tunnel traffic? It will right ?
Marwan ALshawi Thu, 08/07/2008 - 07:50
if the vpn go thorugh this switch interface then the vpn will be part of all traffic and might be droped if the switch port go abpve the limit
if the vpn not thorugh this port then nothing to woory about
Joseph W. Doherty Thu, 08/07/2008 - 10:29
You can also add a class for the VPN traffic and not subject it to the bandwidth restriction.
