Hi all,
I have just installed a test environment of CUAE. After installing all the prerequisites everything seemed to be working and apache successfully started.
After installing the svcplatform, cuas and cume Apache will no longer start.
I am getting the following error:
Processing config directory: c:/program files/cisco systems/unified application
environment/system/apache/conf/
Processing config file: c:/program files/cisco systems/unified application envi
ronment/system/apache/conf/grxml_expires.conf
ronment/system/apache/conf/mce.conf
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\Program Files\PHP\
ext\php_ldap.dll' - The operating system cannot run %1.
in Unknown on line 0
ronment/system/apache/conf/media.conf
ronment/system/apache/conf/metreos_http.conf
Syntax error on line 7 of c:/program files/cisco systems/unified application env
ironment/system/apache/conf/metreos_http.conf:
Cannot load c:/program files/apache group/apache/modules/mod_unique_id.so into s
erver: (126) The specified module could not be found:
I can't figure any of this out on my own any help greatly appreciated.
Jamie
