08-07-2008 07:13 AM - edited 03-06-2019 12:40 AM
CAn anyone advise on the best way to configure a switch port that has a Cisco telephone connected with a PC connected to the phone port.
In the past I was advised that any port that has an IP Telephone connected should be set to trunk mode with dot1q encapsulation. Is this the best way to configure the port or should the port be set to access mode?
Solved! Go to Solution.
08-07-2008 07:26 AM
let say ur data vlan is 10 and voice is 20
switchport mode access
switchport access vlan 10
switchport voice vlan 20
mls qos trust device cisco-phone
spaning-tree portfast
no shut
and the folwoing link for more details
good luck
please, if helpful rate
08-07-2008 07:26 AM
no shut
good luck
