Ayodeji Okanlawon Thu, 08/07/2008 - 07:35
  • Cisco Designated VIP,
    2017 IP Telephony
Phones get their time from the Time Group configured in the device pools. Have you configured the right time there?
gustavo001 Tue, 08/19/2008 - 14:20
I follow the link, but when i try to use de ntpdate command the following message appear:
C:\>ntpdate 10.8.1.50
'ntpdate' is not recognized as an internal or external command,
operable program or batch file.
C:\>
what can I do?
THanks in advance,
Gustavo
jbarcena Tue, 08/19/2008 - 14:24
  • Red, 2250 points or more
I usually follow the steps below and seems to work very good.
1. Go to \Winnt\System32\drivers\etc
2. Open ntp.conf in Notepad
3. Modify the file/content in their to reflect the NTP Server IP address.
For e.g 172.18.106.15 is my NTP Server
server 172.18.106.15 # Set Local Clock to Authoritive Time Source
fudge 172.18.106.15 stratum 5 # Resets Stratum from default 3 to 5
driftfile C:\WINNT\system32\drivers\etc\ntp.drift # path for drift file
4. Go and now stop the Network Time Protocol Service
5. If you want you can now change the time on the box to hour ahead or back, to test if NTP will work or not.
6. Open command prompt and go to \Program Files\Cisco\Xntp
7. Type the command "ntpdate x.x.x.x" - Where x.x.x.x is the NTP server IP address.
C:\Program Files\Cisco\Xntp>ntpdate 172.18.106.15
Looking for host 172.18.106.15 and service ntp
host found : vnt-ntp.cisco.com
29 Sep 14:57:51 ntpdate[924]: step time server 172.18.106.15 offset -10719.468824 sec
8. The NTP will update the clock/date, etc on the server and then should come back to the prompt again.
9. Go back and start the Network Time Protocol Service.
As you can see you do not type ntpdate on the root.
Rob Huffman Tue, 08/19/2008 - 16:38
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Jorge,
As always, an extremely high quality answer from you! +5 points for your continued great work here.
Take care,
Rob
