show ip route issues
Aug 7th, 2008
Does anyone know why when i show ip route to an internet address on a 6513 that has a static route 0.0.0.0 0.0.0.0 to my default gateway firewall. it shows route is not found in the routing table?
Overall Rating: 5 (1 ratings)
Tarun Lohumi Thu, 08/07/2008 - 10:36
  • Cisco Employee,
That's expected behaviour.
When you do a 'show ip route' for a specific destination, it would show you the next hop to reach that destination if it has one or would say '%subnet not in table'.
Default route is used when you do not have a route for a destination, so its technically not a route for that destination, its a gateway of last resort, kind of a dumyard for any unknown destinations.
Edison Ortiz Thu, 08/07/2008 - 10:37
  • Hall of Fame,
    Founding Member
Because the route is not in the routing table.
A default route will instruct the device to send all unknown routes over to the gateway. It does not populate the routing table with 'internet' routes.
HTH,
__
Edison.
