LMS2.6 integration with Cisco ACS
finidchevys
Hi all,
Does anyone know where I can find instructions to integrate ciscoworks lms2.6 with ACS v4.1? I've only been able to find info on integrating lms3.0.
Joe Clarke
ACS integration with LMS 2.6 is only supported up to 4.0. Attached is an HTML document that TAC uses as a rough guide on setting up ACS integration. Many of the steps documented at http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html apply to LMS 2.6 and ACS 4.0 except for the fact that with LMS 2.6, you must create the Super Admin group in ACS manually.
Joe Clarke
Thank you. I really appreciate the info.
Not applicable
Hi jclarke, I have LMS 2.6 and want to integrate with ACS version 4.1(1) build 23
is it possible? If not, do I need to upgarde the LMS to 3.x?
yanic
Joe Clarke
You need to upgrade to LMS 3.0 for this to be officially supported.
