Reporting on Specific Extension
Answered Question
Aug 7th, 2008
Is there a way to run a report on a specific extension to see data on the numbers of calss received and what number calls were transferred to? Thanks!
Correct Answer by Jaime Valencia about 8 years 9 months ago
yes, you can use CAR for that.
search by user/extension
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 08/07/2008 - 10:16
  • Cisco Employee,
  • Hall of Fame,
    2011
java
