Looking for a 2801 WIC
Answered Question
Aug 7th, 2008
I want to connect my Cisco 2801 (C2801-ADVIPSERVICESK9-M) an E1, do you know the part number for WIC modules for 2801 routers ?.
Best regards, thank you.
Correct Answer by Edison Ortiz about 8 years 11 months ago
RJ-48 to BNC?
Well, then the BNC will go to the telco side and the RJ-48 will connect to this unit:
VWIC-1MFT-E1
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
lveraza Fri, 08/08/2008 - 08:21
Thanks Edison,
Do you know If there is another type of WIC, because my ISP is going to give me a V35 interface, I need a serial port.
Do you understand me ?.
Thank you, best regards.
lveraza Fri, 08/08/2008 - 09:29
Edison,
Do you know the part number for the RJ-48 cable of VWIC2-1MFT-T1/E1 ?.
Thank you.
Edison Ortiz Fri, 08/08/2008 - 09:50
  • Hall of Fame,
    Founding Member
RJ-48?
I've always used the standard patch cable on those kind of connections. From the WIC to the telco jack.
__
Edison.
lveraza Fri, 08/08/2008 - 10:00
Yes, do you have this standard patch cable part number ?. is there ?.
Edison Ortiz Fri, 08/08/2008 - 10:03
  • Hall of Fame,
    Founding Member
There isn't a part number. You can find that kind of cable basically anywhere. It's the same cable you would use to connect your PC to a network jack.
__
Edison.
lveraza Fri, 08/08/2008 - 10:06
Ok, I understand you, but I receive from ISP a coaxial cable with BNC connector, do you understand me ?.
Ther is a cable with Rj-48 to BNC for this connection.
