random disconnection approx once in an hour
Aug 7th, 2008
CDT: *** Not encrypted dot1x packet from 001e.5226.274b hasbeen discarded
CDT: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 001e.226.274b Associated SSID[turbospeed] AUTH_TYPE[OPEN] KEY_MGMT[WPA PSK]
CDT: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001e.5226.274b Reason: Previous authentication no longer valid SSID
Scott Fella Fri, 08/08/2008 - 04:55
Is the device not being used and the wireless card shut's down. Take a look at the wireless device setting and check the power management setting. Try setting it to Constant Awake Mode or it might be stated as Maximum Performance in the power management settings.
If you have a WLC, maybe play around with the idle session timeout. If you don't have a wlc, don't worry about this.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
