800 Series Router WAN Throughput
Aug 7th, 2008
Can anyone tell me which 800 series routers allow 20 Mbps throughput across the WAN port?
I have a cable modem that outputs this speed but am having difficulty finding a router that will accept this throughput across the WAN port.
Thanks.
Overall Rating: 5 (1 ratings)
Collin Clark Thu, 08/07/2008 - 13:13
  • Purple, 4500 points or more
The 871 and 881 have at least 32 Mbps firewall throughput. The WAN port is 10/100 so 20 Mbps throughput is no problem.
Hope that helps.
davidstrg99 Thu, 08/07/2008 - 13:16
That's exactly the information I'm looking for.
Other 800 series also have 10/100 WAN ports but reportedly do not transfer more than 10 Mbps.
Thank you.
davidstrg99 Thu, 08/07/2008 - 13:40
Now I'm confused again.
Customer support told me that the 871 supports 30 Mbps VPN so shouldn't it at least support 30 Mbps non-VPN across the WAN port?
rkhalil Thu, 08/07/2008 - 14:05
  • Bronze, 100 points or more
emm.. remember cisco say, the performance of laboratory tests..
The Perfomance of the Router
varies sharply according to different factors including the size of package and the kind of traffic..
From bottom of page http://www.cisco.com/en/US/partner/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
Performance
Q. What are the performance characteristics of the Cisco 870 Series and Cisco 850 Series Integrated Services Routers?
A. Aggregate performance with IPsec 3DES for the Cisco 870 Series is up to 8 Mbps with IMIX packets, and up to 30 Mbps with 1400-byte packets.
Aggregate performance with IPsec 3DES for the Cisco 850 Series is up to 4 Mbps with IMIX packets, and up to 8 Mbps with 1400-byte packets.
IMIX == Internet Mix Traffic.
Raul
(please rate helpful posts)
Joseph W. Doherty Thu, 08/07/2008 - 15:26
As Raul notes, performance varies much, especially based on packet size. Large packets (best case) often quoted for impressive throughput. 64 byte packets usually the benchmark for (worst case). IMIX often the bencmark for (average case).
Joseph W. Doherty Thu, 08/07/2008 - 17:16
Often up to 1500 bytes, but the average size should be around 300 to 40 bytes, but with many packets both minimum and maximum sized.
Cameron Webster Mon, 03/26/2012 - 11:18
I've found this area quite confusing and have seen conflicting information regarding router throughput.  From this document (http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf), the throughput on the 870 router is 12.8 Mbps.  I'm currently using my own 871w router as the WAN side connection on an unmanaged fibre connection (no firewall - just routing) and I'm seeing 50Mbps through it.
Can anyone explain this?
Cammy
Leo Laohoo Mon, 03/26/2012 - 15:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The value stated on this PDF document is expressed in HALF duplex and without any encryption.  So if you want FULL duplex or with encryption then you halve the value.  If you want FULL duplex AND with FULL encryption then you take the full value and factor it by four.
Cameron Webster Wed, 03/28/2012 - 02:24
Running my 871 with no encryption, full duplex 100 Mbps at both sides, I'm seeing at least 50Mbps (limited by the speed of the circuit), this is not a fraction of 12.8 Mbps
Joseph W. Doherty Mon, 03/26/2012 - 18:02
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Depends on your packet sizes and features being used.  For instance, Cisco says the 860 (same nominal performance as an 870) can push 197 Mbps for 1500 byte packets doing nothing but packet forwarding yet they recommend the 860 for WAN circuits up to only 4 Mbps.
I've attached a later Cisco document that better explains performance.
Cameron Webster Wed, 03/28/2012 - 02:27
Thanks.  Presumably performance degradation when using encryption occurs on the router that is doing the encrypting, not on a router which is simply routing traffic?
Joseph W. Doherty Wed, 03/28/2012 - 02:32
Disclaimer
Posting
Or decryption or other services; otherwise correct.
Paolo Bevilacqua Wed, 03/28/2012 - 11:37
  • Hall of Fame,
    Founding Member
Cisco routers have hardware encryption. Consequently, there is not much performance difference.
John Peterson Sun, 09/16/2012 - 02:02
I'm also having the same confusion. Our 881 shows on paper to push  roughly 12Mbps, but when using simple routing and acl we are obtaining speeds of 70Mpbs.
Therefore I don't see the pdf, is correct in any way, and if this is half duple then surely the speed is doubled on full not halfed. Unless I'm missing something.
I would appreciate if someone could please explain.
Paolo Bevilacqua Sun, 09/16/2012 - 02:10
  • Hall of Fame,
    Founding Member
You have an 881, not an old "800 series"..
Above has been linked the white paper to reference for ISR G2 routers, that is consistant with your performance observation.
Table 1. Cisco ISR G2 RFC 2544-Based Performance (kpps and Mbps)
kpps
(64-byte packets)
25 50 100 290 330 330 352 479 579 833 1845 982 2924
Mbps
(1500-byte packets)
197 198 1400 2770 2932 3114 3371 3502 5136 6903 6703 8025 8675
Please rate useful posts clicking on the stars below.
John Peterson Sun, 09/16/2012 - 02:15
Hi Paolo,
Thank you,
Therefore a Cisco 881 should be able to router over 100Mbps of traffic?
I also have some old routers which I would like to use in our lab, how do I find out which routers these are? I know the model numbers but the 'G2' section?
Paolo Bevilacqua Sun, 09/16/2012 - 04:31
  • Hall of Fame,
    Founding Member
Yes, about that.
For lab purposes, performances are not important.
Thank you for the nice rating and good luck!
John Peterson Sun, 09/16/2012 - 05:04
I understand but these router in our labs we use on production environment post testing features.
How were you able to identify G2 routers?
Your welcome on the rating.
