Jaime Valencia Thu, 08/07/2008 - 12:38
  • Cisco Employee,
  • Hall of Fame,
    2011
where do you have it blocked???? you don't say that
java
if this helps, please rate
houstonrob Thu, 08/07/2008 - 12:40
Route pattern
Calling line id presentation: restricted
Calling name presentation: restricted
Can i block it elsewhere instead that would allow me to accomplish what i want?
Jaime Valencia Thu, 08/07/2008 - 13:05
  • Cisco Employee,
  • Hall of Fame,
    2011
easiest way would be to configure a route pattern 9.@ and that only that particular user could reach it
otherwise you would need to create a copy of each route pattern and have it on a partition that only that user can use
java
vpreenja Thu, 08/07/2008 - 20:26
If you are not using any " calling party mask" at the route pattern or route list , you can apply a fake " External mask" at the device level for the devices whose caller id you want to block.
Check " use calling party mask" at the route pattern .
houstonrob Fri, 08/08/2008 - 12:04
Thanks for the ideas, I'll try them out and see what works best for us.
