Error Message
Answered Question
Aug 7th, 2008
Has anyone ever seen
Registration Rejected:Error Misma...
If so, how do you fix?
Correct Answer by Jaime Valencia about 8 years 10 months ago
you're trying to configure a phone using a wrong model
ie you have a 7941G and you used 7941G-GE when registering it
use the right model or use auto-registration
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 08/07/2008 - 12:37
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Pari Thiagasundaram Thu, 08/07/2008 - 12:47
  • Silver, 250 points or more
If you have a regular 7941 and are creating IP Phones as 7941G-GE, then you might endup with this error.
