ACS 4.1 cert issue (2048bit?)
Answered Question
Aug 7th, 2008
I am trying to install a .p7b cert on our ACS, I get 'Certificate file is in invalid or unsupported format.'
I know 2048bit certs were not supported in 3.3, is that still the case?
Correct Answer by Scott Fella about 8 years 11 months ago
Yes it is still the case. Look at this doc and do a seach for Key Size-1024**
The doc states:
Note: The Windows 2003 Enterprise CA allows key sizes greater than 1024. But, the use of a key larger than 1024 does not work with PEAP. Authentication might appear to pass in ACS, but the client just hangs while it attempts authentication.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a0080545a29.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Thu, 08/07/2008 - 19:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The doc states:
Trending Topics - Security & Network
