Darn it: Exam 642-432!
I have just learned that 642-432 has been replaced with 642-436. At the surface the outlines look a lot a like. I just ordered the 642-436 Cisco press self study guide to learn the deltas. Can anyone help on focus points on the differences between the two exams?
What is the difference between 642-432 and 642-436?
Thanks.
tim.giles Tue, 09/16/2008 - 07:04
Most of it is the same to be honest but they've stripped out quite a bit of info and added bits and pieces in to update it.
Stuff about E&M, troubleshooting dial peers/ports/signalling etc and PBX info have all been removed.
Here's some links on the certification track to show you what the main differences are, hope it help and good luck!
CVoice 642-432
http://www.cisco.com/web/learning/le3/current_exams/642-432.html
CVoice 642-436
http://www.cisco.com/web/learning/le3/current_exams/642-436.html
Please rate useful posts....
