ASA 5505 webservice (soap) and NAT
Aug 7th, 2008
We have recently deployed an ASA 5505, with a webservice behind this device. Web traffic works fine, but not the appliction used to access the xml webservice. So far I have not been able to find any solutions.
Marwan ALshawi Thu, 08/07/2008 - 16:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
can u post ur config and details about this abblication
such as which port it use
markverret Fri, 08/08/2008 - 06:49
Attached is my configuration file. We are using a standard microsoft .net 1.1 xml webservice on port 80. From what I can tell the client is able go get an initial message to the server app, but further communication does not happen.
Marwan ALshawi Fri, 08/08/2008 - 07:56
remove this policy
olicy-map type inspect http webservice
parameters
protocol-violation action drop-connection
and any http inspection
this one aswel remove it
inspect http
because from what u said i think there is somthing blocking the content as long as u have the basic http connection
try it and let me know
good luck
markverret Fri, 08/08/2008 - 10:31
marwanshawi, I removed the suggested entries but still am not able to connect. Any other suggestions?
