SSID not showing
Answered Question
Aug 7th, 2008
The company I work for has all its APs controlled by a WISM. I recently deployed an AP out to a WAN site and when the AP boots up, I am able to see on the WISM, able to ping from the WISM and vice-versa, able to ping the IP addresses of the SSID from the switch and vice-versa; however, my laptop is not able to see any SSID. The AP is connected to WS-3560-25TS. Where did I go wrong here?? I am confused. This should be no different than any other site, isn't it??
Correct Answer by Scott Fella about 8 years 9 months ago
Are you broadcasting that ssid? Is the ap in local or h-reap mode? Also, are you using any AP Groups or have AP Groups Configured.
If the AP has joined the WLC, you should be able to see that ap on the gui or on the cli. If the ap is there, then click on the wireless tab then under radio, click on 802.11a/n or 802.11b/g/n and see if the radios are up. Also verify that that ap is enabled and not disabled.
Overall Rating: 4 (1 ratings)
Correct Answer
Scott Fella Thu, 08/07/2008 - 19:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
s-menezes Fri, 08/08/2008 - 12:47
Fella5:
Thank you for your response.
(1) The WISM has 3 SSID, 2 being broadcast and one its not. Out of the 3 I am only "seeing" the one that its not broadcasting. Its like I see 1 out of 3 SSIDs.
(2) I do not have any AP groups
(3) I can see the AP at the WISM, ping it, move it around to different WISMS in our network etc..
(4) Under the radio,802.11a/n and 802.11b/g/n, the radios are up and enable..
What can cause my laptop only to see 1 out 3 SSID?? Never seen this type of problem...
phillsolomon Sun, 08/10/2008 - 15:54
You didn't say which ver you are using, but I had a similar issue with 5.0.148.
When adding a WLAN, I found I needed to reboot the AP for it to start broadcasting it. Do an AP reboot - does it help?
dennischolmes Mon, 08/11/2008 - 05:31
  • Gold, 750 points or more
Use version 4.1.185 or 5.1.x This solved several issues on WiSMs. 4.1.185 is the most stable.
s-menezes Mon, 08/11/2008 - 06:25
Dennis:
All my WISMs are running ver 4.1.85.
Thanks...
s-menezes Mon, 08/11/2008 - 06:27
Phill:
All my WISM uses ver 4.1.85. I have rebooted the AP and the switch, but problem still there. I will replace the switch next.
Thanks...
s-menezes Tue, 08/12/2008 - 10:53
Scott:
I verify your suggestion and I went a step further by replacing the switch and the AP; however, I still have the same weird problem. Can you program an AP, connected to a controller, to block SSIDs??
Thanks...
Scott Fella Thu, 08/14/2008 - 06:07
  • Hall of Fame,
    2017 Wireless
You can configure the wlc to only have certain ssid's on it. that would be using the wlan override feature.
Delete the ssid from the wlc and create a total new one with no encryption at all and see if you can see it. Sometimes when you mess around with an ssid it gets corrupted and deleting it and recreating it can fix it.
Let me know
Post your show run-config or show running-config on one of your wlc that the ap is one so we can see if it is setup right.
s-menezes Thu, 08/14/2008 - 06:07
Scott:
When you first asked if I was broadcasting the WLAN, I checked the wrong controller. When I started to compare configs bt controllers I realized what was missing.
Thanks...
Scott Fella Thu, 08/14/2008 - 06:23
  • Hall of Fame,
    2017 Wireless
Well I guess everything is working okay now.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
