ACS verison 3.3
Answered Question
Aug 7th, 2008
hi, in our environment we have Cisco ACS v3.3 in windows 2003 and trying to upgrade it ACS v4.1.4. but found the data replication from v3.3 to v4.1.4 is causing a issue.
Pls let us know is there way to do data replication with this different code.
thanks
Gopinath V
Correct Answer by srivchan about 8 years 11 months ago
Hi Gopinath,
For replication process, the primary & secondary servers should be in same version.
Kindly upgrade primary & secondary to 4.1.4 and initiate the replication.
Snippets from User Guide:
"All ACSs that are involved in replication must run the same release of the ACS software. For example,
if the primary ACS is running ACS version 3.2, all secondary ACSs should be running ACS version 3.2.
Because patch releases can introduce significant changes to the ACS internal database, we strongly
recommend that ACSs involved in replication use the same patch level."
If both ACS (primary & secondary) are in same version and still your are facing some issues, let me know.
Srividhya
Overall Rating: 3 (1 ratings)
Correct Answer
srivchan Thu, 08/07/2008 - 21:22
Hi Gopinath,
Srividhya
gopinathv Sat, 08/09/2008 - 20:50
thanks for this information. i was able to do data replication with two server running 4.1.4 code..
thanks
