8/2 2821 Router
Aug 7th, 2008
I am having trouble getting information.
I am installing a new network with a business class cable modem with 8mb DL, and 2mb UL...
Will the 2821 ISR handle this for my network?
Mark Yeates Thu, 08/07/2008 - 14:58
The 2821 is more than sufficient for the specified speed of your cable modem.
Joseph W. Doherty Thu, 08/07/2008 - 15:16
As Mark notes, more than sufficient, overkill even. However, if you'll also be using it for LAN routing, in addition to WAN routing, it could handle a couple of 10 Mbps links, but it won't sustain either 100 or gig speeds, even though it has gig Ethernet interfaces.
timcappalli Thu, 08/07/2008 - 16:22
I'll be honest, I have been maintaining networks in the past but I have never built one, so I am having some trouble...
Here is my situation...
We are a small public access station. We have video servers which play out video to our video transmitters. These servers will be connected to our gigabit switch along with our editing computers and laptops. This gigabit throughput is only needed locally, as all computers are hooked into the switch. So am I right to say that the router does not need to hangle gigabit speeds? I plan on doing DHCP through the switch and using the router for firewall, vpn, and routing.
Is there a lower model of these routers that would work also? We have budget limits so I would like to save money in any way possible.
Thanks for all your help!
Joseph W. Doherty Thu, 08/07/2008 - 17:11
Yes, if all your computers, internally, are on the same network, a gig switch will handle the traffic between them. The router will only come into use when moving traffic to/from the Internet where the DSL bandwidth is the limiting factor. Also yes, a less expensive router could be used for your DSL, such as one of the 800 series or you could even consider a Linksys router.
timcappalli Thu, 08/07/2008 - 17:12
Would that 800 series be able to handle the firewall, VPN, and routing all in one box?
I dont know if you need to know this but I have 5 static IPs, one for the LAN and 4 for the servers....
Would I be OK with one of the 1800 series models?
