UC500 CUE Clock Unsync
Aug 7th, 2008
Dear All,
Is it normal that the clock state is unsync in UC500-CUE?(I have only one at hand).
UC500-CUE# sh clock detail
12:35:41.236 NZST Fri Aug 08 2008
time zone: Pacific/Auckland
clock state: unsync
delta from reference (microsec): -14410
estimated error (microsec): 66869
time resolution (microsec): 1
clock interrupt period (microsec): 10000
time of day (sec): 1218155741
time of day (microsec): 247760
Recently I have a problem of 12-hour time shift in the Voicemail messages. Messages recorded in AM is reported as in PM. NTP on both CME and CUE are correctly synced, but the clock state in CUE shows unsync.
Any reference to sync the clock?
Thanks in advance.
exonetinf1nity Fri, 08/08/2008 - 06:16
Have you configured an NTP server within unity express?
CME Config
interface Loopback0
description Loopback For UnityExpress
ip address 10.10.10.2 255.255.255.252
interface Integrated-Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 10.10.10.1 255.255.255.252
service-module ip default-gateway 10.10.10.2
no keepalive
ntp master
CUE Config
CUE>ntp server 10.10.10.2 prefer
saturn117 Sun, 08/10/2008 - 12:49
Thanks to the reply.
The NTP is syncronized. The clock shows correct time and date, but the clock state still shows uncrync even after reloading.
Do you suggest a CUE upgrade?
