Warning message
POST XML to 7960 failed
Aug 7th, 2008
I've been trying to test the CiscoIPPhoneExecute component. I installed the SDK and the CM-Sim.
The HTTP Get method works, that is, after pressing the 'services' button, the phone get the <CiscoIpPhoneExecute> Key:Speaker URI and execute it (though I don't know why other keys failed, eg. KeyPad0~9).
But the HTTP POST failed. I config the authentication url to my own hack asp page that always sends 'AUTHORIZED'. So I think authentication is not a problem. I always get a '404 Not Found' response from the phone. The HTTP msg I send is:
POST http://<phoneIP>/CGI/Execute
Authorization: Basic text2base64(userID + ":" + password)
Connection: close
Content-type: application/x-www-form-urlencoded
XML=<CiscoIPPhoneExecute><ExecuteItem Priority="0" URL="Dial:1000"/></CiscoIPPhoneExecute>
And from snifer, I see the 404 response from the phone is
<HTML>
<H1>object Not Found</H1>
The requested URL '/CGI/Execute' was not found on the Rompager server.<P>
I don't know why the '/CGI/Execute' was not found on the phone? Am I missing something?
Thanks.
stephan.steiner Fri, 08/08/2008 - 07:38
  • Silver, 250 points or more
Do you get the same result if you take the content below and put it into a html file, then do the whole thing via browser (it must not be IE.. IE7 somehow broke this simple page)
http://10.145.7.131/CGI/Execute" Method="POST">
duwei9811 Fri, 08/08/2008 - 16:50
Thanks for your help. The HTML you give works. And I also get my XML working. The problem is due to the incorrect URL encoding function I used in HTTP request body.
But I have another question with the Dial:xxxx URI in the CiscoIPPhoneExecute component. When I send
I always see the "AutoDial Cancelled" message on the LCD. Does anybody have any idea about this? How do I make phone A call phone B with XML?
Thanks!
duwei9811 Mon, 08/11/2008 - 16:38
Just ask again because I'm working to solve this but I cannot find any clue elsewhere. Does anybody have any idea what's this "AutoDial Cancenlled" mean and how to make Dial URI work?
Thanks!
agiaccone Tue, 08/12/2008 - 07:45
  • Bronze, 100 points or more
Maybe you could find some useful information on the console logs of the IP Phone. Check them out here :
http:///CGI/Java/Serviceability?adapter=device.statistics.consolelog
HTH,
Alberto
