WAAS CIFS in 4.1
Aug 7th, 2008
In WAAS 4.0 WAE-NME302/502 were not able to export servers (i.e. configured for CIFS core function). Is this limitation removed in 4.1, with symmetric CIFS implementation?
Overall Rating: 5 (1 ratings)
dstolt Thu, 08/07/2008 - 20:53
  • Cisco Employee,
NME-WAE-302 doesn't support the CIFS AO due to only supporting transport and not enterprise license. The NME-WAE-502/522 should support bi-directional CIFS, however it will be limited in connection counts per established sizing guidelines.
Dan
d.gabo Sun, 08/10/2008 - 19:52
Thanks Dan,
Where can I get the sizing guide? I have WAAS sizing spreadsheet for 4.0.13, b ut it does not have any CIFS details.
David
ropethic Thu, 08/14/2008 - 13:08
  • Silver, 250 points or more
The number of CIFS TCP connections is included in the total number of supported TCP connections.
NME-WAE 302 - 4Mbps 250 TCP connections
NME- WAE 502 - 4Mbps 500 TCP conn
NME-WAE 522 - 8Mbps 800 TCP conn
WAE-512 w/1G - 8M 750 TCP conn
2G - 20M 1500 TCP conn
WAE-612 2G - 45M 2000 TCP conn
4G - 90M 6000 TCP conn
WAE-7341 - 310Mbps 12000 conn
WAE-7371 - 1G wan 50,000 tcp conn
