restricting DHCP flooding on CISCO 2960 switch
Aug 7th, 2008
We are one of the service providers having both static IP and DHCP customers... One of the BTS sites we have deployed a cisco 2960 switch to which BTS is connected through which DHCP customers connect..On the same switch a few static IP customers also terminate(Point to Point radio)... In one case a static IP customer terminated our link to his LAN port of the router in stead of the WAN port by mistake and our DHCP customers started getting IPs from his IP Pool... Is there anyway we can prevent this on the switch port on which the static ip customer terminates...
Marwan ALshawi Thu, 08/07/2008 - 22:46
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u can preven this by useing DHCP snoopng
just enable it golbaly
then
enter this command on each interface that u dont want it to offer DHCP
and enter this command with the word TRUST to each port connected to a DHCP server
in other word any oport configured with DHCP snoorping will be untrusted port so will not accept DHCP offres through it
while when u add the word "trust" to that command on the port level here u r trusting this port and accepting DHCP offers
Important:
make each port connect to DHCP server ( imean servers u want use) as dhcp snooping trust
also this command should be entered on ports or trunks connecting switches
all other ports
not trusted
dhcp snooping
also u can limit the rates for more advnced security
also this link good refrence
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/dhcp.html
good luck
please, if helpful rate
