08-07-2008 11:47 PM - edited 03-06-2019 12:41 AM
I would like to ask your help for a cat0s 6500 switch which faces some errors on some interfaces..
Some of the logs indicating this situations show:
. cat6500 x.x.x.x Jul 29 2008 00:04:31 SYS 3 PORT_IN_ERRORS Port 3/25 detected 2295 input error(s) in last 30 minutes *
3. cat6500 x.x.x.x Jul 29 2008 00:04:31 SYS 3 PORT_FCS_ERROR Port 3/25 detected 2119 FCS error(s) in last 30 minutes *
4. cat6500 x.x.x.x Jul 29 2008 00:04:31 SYS 3 PORT_OUT_DISCARD Port 3/27 detected 471246 output discard error(s) in last 30 minutes *
5. cat6500 x.x.x.x Jul 29 2008 00:04:31 SYS 3 PORT_OUT_DISCARD Port 3/39 detected 2393203 output discard error(s) in last 30 minutes *
6. cat6500 x.x.x.x Jul 29 2008 00:34:17 SYS 3 PORT_ALIGNMENT_ERROR Port 3/25 detected 2068 alignment error(s) in last 30 minutes *
7. cat6500 10.70.16.7 Jul 29 2008 00:34:17 SYS 3 PORT_IN_ERRORS Port 3/25 detected 2248 input error(s) in last 30 minutes *
8. 3g-cat6500 x.x.x.x Jul 29 2008 00:34:17 SYS 3 PORT_FCS_ERROR Port 3/25 detected 2068 FCS error(s) in last 30 minutes *
9. cat6500 x.x.x.x Jul 29 2008 00:34:17 SYS 3 PORT_OUT_DISCARD Port 3/27 detected 408155 output discard error(s) in last 30 minutes *
10. cat6500 x.x.x.x Jul 29 2008 00:34:17 SYS 3 PORT_OUT_DISCARD Port 3/39 detected 2379557 output discard error(s) in last 30 minutes *
11. cat6500 x.x.x.x Jul 29 2008 01:03:57 SYS 3 PORT_ALIGNMENT_ERROR Port 3/25 detected 2071 alignment error(s) in last 30 minutes *
12. cat6500 x.x.x.x Jul 29 2008 01:03:57 SYS 3 PORT_IN_ERRORS Port 3/25 detected 2226 input error(s) in last 30 minutes *
13. 3g-cat6500 10.70.16.7 Jul 29 2008 01:03:57 SYS 3 PORT_FCS_ERROR Port 3/25 detected 2071 FCS error(s) in last 30 minutes *
14. cat6500 x.x.x.x Jul 29 2008 01:03:57 SYS 3 PORT_OUT_DISCARD Port 3/27 detected 241473 output discard error(s) in last 30 minutes *
15. cat6500 x.x.x.x Jul 29 2008
01:03:57 SYS 3 PORT_OUT_DISCARD Port 3/39 detected 2365998 output discard error(s) in last 30 minutes *
16. cat6500 x.x.x.x Jul 29 2008 01:33:30 SYS 3 PORT_ALIGNMENT_ERROR Port 3/25 detect...
Have you any idea why i see some many error for those interfaces? Do you know how could i avoid/improve this situation? It seems to be overloaded interfaces..
I would appreciate your feedback.. Any ideas/help are welcome..
best regards,
Spyros
08-08-2008 03:50 AM
Looks like you have a number of speed duplex mismatches between the switchport settings and the nic settings on the pc's or servers . Match both ends for speed/duplex settings , if switchport is set as auto then the nic on the far end has to be auto also , if hardcoded to a specific speed/duplex then the nic has to also be hardcoded to the same setting.
08-08-2008 04:20 AM
Thanks for the feedback. The duplex settings are ok. The mentioned interfaces belong to port channels and i see the messages affect only one of the ports.
Do you have any idea?
Spyros
08-08-2008 06:13 AM
I am curious to see your port channels configuration for both devices. In the mid time, here is an interesting link:
08-08-2008 06:43 AM
Thanks for your time:
From the cisco side (catos). I am just copying some commands for one pair. The messages concern 3/25 as you see.The ports are trunk:
(config is missing)..
set port channel 3/25, 4/34 2
set port speed 3/25, 4/34 100
set port duplex 3/25, 4/34 full
set trunk 3/25, 4 on dot1q
set spantree portcost 3/25 200000 mst
The other side is some juniper which i do not have access...
Any ideas?
Spyros
08-08-2008 07:46 AM
If I understand this correctly, you are doing etherchannel between your switch and a juniper device. Right? If so, you should make sure that both sides do agree on the configuration parameters.
It seems also that you also have errors on other interfaces such 3/27 and 3/29. In any case, I am not quite familiar with catos but I do think that the portcost should be between 0 and 65535 but you have it at 200000.
09-12-2008 01:52 AM
This is an old post from my side but the problem still persists. I still receive those messages with errors as i have described to you..
No etherchannel configuration, no cdp. The sh top (catos) shows for fa3/39 (buffer overflow errors) but the links are not fully utilized. Guys i do not know what else to think...
I put the jumbo frame option in one of the interfaces but the errors are still there.
Please help if you are familiar how to eliminate those errors..
Spyros
