Warning message
BRI troubleshooting
Aug 8th, 2008
Now, BRI troubleshooting.
please technical advices me that look attached file about debug isdn status.
following message is isdn status log.
ISDN status:
#sh controllers bri
BRI unit 0:
layer 1 operating in LT-T mode.
Layer 1 is PENDING ACTIVATION. (ISDN L1 State F4)
D Channel Information:
idb at 0x4647D748, driver data structure at 0x46495F44
Infineon Chip Version 0x1
Infineon Registers:
Int. Status Register [ISTA]=0x00, Aux. Int. [AUXI]=0x00
D-channel: Int. Status Reg: [ISTAD]=0x00, Status. Reg: [STARD]=0x40
Mode Reg: [TR_MODE]=0x01
Transceiver Reg: [TR_CONF0]=0x00
Test mode Reg: [TMD]=0x00
IOM Control Reg: [IOM_CR]=0x08
Status Register [STAR]=0x40, Mode Register [MODED]=0xCA
Serial Data Strobe Control Reg: [SDS1_CR]=0x00, [SDS2_CR]=0x00
RX Buffer Descriptor is at 0x46496310, Buffer size 1524
pak=0x46496954 data_ptr=0x3F850FB4 partial_size=0x0
TX Buffer Descriptor is at 0x464962C4
pak=0x0 data_ptr=0x0 partial_size=0x0
0 missed datagrams, 0 overruns
0 bad datagram encapsulations, 0 memory errors
0 transmitter underruns 0 d channel collisions
B1 Channel Information:
B2 Channel Information:
#sh isdn status(calling)
Global ISDN Switchtype = ntt
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = ntt
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 255, Ces = 1, SAPI = 0, State = ESTABLISH_AWAITING_TEI
Layer 3 Status:
0 Active Layer 3 Call(s)
CCB:callid=8004, sapi=0, ces=1, B-chan=1, calltype=VOICE
Active dsl 0 CCBs = 1
The Free Channel Mask: 0x80000002
#sh isdn status(call out)
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Giuseppe Larosa Fri, 08/08/2008 - 02:14
  • Hall of Fame,
    Founding Member
Hello Shigenori,
You have problems at ISDN Layer1 check cables, isdn switch type is NTT and should be fine if you are in Japan
Use switch type basic-ntt I'm afraid ntt is for PRI
ESTABLISH_AWAITING_TEI means that layer2 ISDN q.921 is waiting to receive a valid ISDN TEI that is sort of local address.
From debug we see
Aug 6 14:56:29 JST: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Aug 6 14:56:29 JST: ISDN BR0/0/0 EVENT: handle_l2d_srq_mail: Activating Layer 1
*Aug 6 14:56:29 JST: ISDN BR0/0/0 EVENT: isdn_sw_cstate: State = 4, Old State = 0
PRI will not require a TEI but BRI expects it to work
see
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b76.shtml
Hope to help
Giuseppe
Giuseppe Larosa Fri, 08/08/2008 - 02:20
  • Hall of Fame,
    Founding Member
Hello Shigenori,
ntt is ok, basic-ntt does not exist
sorry for that.
follow the instructions on the link you need to restart the BRI because it is waiting a response from switch
F4
Awaiting Signal
When the TE wishes to initiate activation, it sends an Activation signal to the NT and awaits a response.
Hope to help
Giuseppe
